Being RHD you have to deal with the Twin remote Servos, which can be a pain in the bum :roll:
If your not loosing fluid then you probably have air trapped in the system somewhere, especially if you "pump" the pedal it then goes "hard".
Anyway Suggest you try and check the following:
1.. Check one way valve in hose from manifold to servos is in the right way round and working.
2.. No splits or leaks in the vacuum hose.
3.. Use a pressure bleeder, Guyson do a reasonable one
4.. Always bleed the two servos first.
5.. Then do the back calipers, then the RHS front then the left front
6.. On the fronts do the inside, outside then the top (Correct me if I am wrong please)
7.. The bit that always gets forgotten because they are such a pain to get at are the remote servo air filters, on the bottom difficult to get to. If they get clogged the diaphrams cannot "breath" properly
8.. THe master cylinder can start to go, check around in the footwell for fluid seepage.
9.. Remote servos fail, as stated and start to fill with fluid
You can get "new" servos but they are very expensive. However there are exchange ones available (Jaymic et al) and there is a company that will resleeve them in stainless steel, can't remember the name, but they often advertise in magazines such as Practical Classics.
Remotes are the same as a 2002Tii.
HTH
Malc
PS Added after thinking about it for a while....
10.. Check the hose from the reservior into the master cylinder, plus the plastic dooby the fits in the "bung" on top
11.. Pump the pedal at the same time as having a pressure bleeder on!
12.. Don't use a lot of pressure in the bleeder - 10 - 15psi is enough
13.. Is the master cylinder new?
If the pedal goes to the floor after leaving the car overnight, but pumps up after a couple of goes, keep you foot on the pedal and start the car, does it go down further? - if so I would suspect a valcuum leak somewhere. Same after you have run the engine, turn it off and pump the pedal, does the feel change? - leave it over night - different again?
Sorry to keep chucking this stuff out but it's how the remains of my brain works!
