How many CSL Batmobiles were produced?
jgmoney
New Member
San Francisco, CA
I've read there were anywhere from 57 to 167 Batmobiles produced. Does anyone know the correct number?
What's the going rate of a CSL and CSL Batmobile, both in good condition?
Jim
Not sure of the numbers of "bats" produced but they go for silly money. Here in the UK last year at one of the London auction houses one made arround £85,000 (pounds sterling) Working on the basis that here in the UK the CS Coupe is worth a lot less than they are in America I wouldn't even try to guess what they would be worth over there.
I was also shocked to see the price that car fetched ... I did hear afterwards that the car went to a collector in the Middle East ... perhaps that helps explain the high price :shock: :?
Tyler said:
CSL production, from http://www.bmwmregistry.com/model_faq.php?id=1
3.0 Carburettor (LHD): 169 built from 9/71 thru 7/72
3.0 Injection (LHD): 429 built from 9/72 thru 6/73
3.0 Injection (RHD): 500 built from 9/72 thru 1/73
3.2 injection (LHD): 110 built from 7/73 thru 10/73, 57 built from 1/74 thru 10/75
Correct, but only a small subset of the CSL production are Batmobiles.
Wikipedia says 57. http://www.usautoparts.net/bmw/models/vintage/batmobile.htm says 167.
According to the green Mobile Tradition coupe book (Profiles 5, p/n 01 09 0 004 125), there was an initial run of 110 Bats (3,153cc) in July 1973. Between 6/74 and 10/75, 57 more were built.
The US CS Registry also bears these numbers out:
http://www.bmwcsregistry.org/Coupe_Information/e9production.html
So, 167 it appears to be.
Value? Consider that many auctions (Barrett Jackson, etc.) have open bars for the folks with fat wallets.
While road legal Bats have an almost mythical status I assume this was all to do with Homolgation issues, there were surely alot more racing cars out there, even if based on "lesser" models and ended up with all the bits screwed on.
My question would be whatever happened to them. A few no doubt crashed and written off but are they hiding in sheds somewhere?
I should be told.
Malc
History
What makes the 3.0 CSL unique?
The 3.0 CSL is a lightweight, performance-oriented version of the standard 3.0 CS/3.0 CSi coupe. It was originally developed as a homologation model for the German Touring Car Championship by a separate division within BMW AG, a division that would later become BMW Motorsport GmbH.
Where was the 3.0 CSL first introduced?
The 3.0 CSL was first unveiled at the 1971 Geneva Motor Show.
Is the 3.0CSL considered an M car?
Because the 3.0 CSL was conceived by BMW's competition department, which would be formally incorporated in 1972 as BMW Motorsport GmbH (later renamed BMW M GmbH), it is therefore generally considered to be the first M Series model. Though it does not carry an M badge, the 3.0 CSL would eventually be offered with the tri-color stripes that would form the icon of the M division.
What do the letters "CSL" designate?
The "CS" suffix denotes "Coupe Sport" and was introduced with the Bertone-designed 3200 CS of 1962. The "L" was added to this version of the 3.0 CS in order to denote "Lightweight"
How much lighter is the 3.0 CSL compared to the steel-bodied 3.0 CS?
According to official BMW figures, a non-optioned 3.0 CSL with all the aluminum body panels weighs 2,568 pounds or about 440 pounds less than an equivalent 3.0 CS. City Package-equipped models are 297 pounds heavier than the standard 3.0 CSL at 2,865 pounds.
Why is the later 3.0 CSL sometimes referred to as the "Batmobile"?
In addition to the standard front airdam and rear spoiler, 3.2-liter CSL models could be fitted with a removable "racing kit" consisting of an air guide mounted above the rear window and an enlarged rear spoiler, both designed to increase downforce on the competition machines. The addition of these rather striking appendages resulted in the nickname "Batmobile." Because these items were required on the road version for homologation purpose but could not be installed at the factory due to a conflict with various European laws, they were supplied as the removable kit.
Production Data
How many versions of the 3.0 CSL were developed?
BMW developed four different versions of the 3.0 CSL over five years, all to European specification. The original version, produced in late 1971 and early 1972, utilized the standard 2,985-cc M30 engine with twin carburetors and was only offered in left-hand drive. A fuel-injected model displacing 3,003cc then replaced the earlier carbureted version and was produced in both left-hand drive and right-hand drive forms during late 1972 and early 1973. The final iteration of the 3.0 CSL, all produced in left-hand drive and with a larger 3,153-cc engine, was built in two distinct production runs during late 1973 (first batch) and 1974-75 (second batch).
How many of each version of the 3.0 CSL were produced?
3.0 Carburetor (LHD): 169 produced from 05/1971 through 07/1972
3.0 Injection (LHD): 429 produced from 09/1972 through 03/1973
3.0 Injection (RHD): 500 produced from 09/1972 through 06/1973
3.2 injection (LHD): 110 produced* from 07/1973 through 01/1974, 57 produced from 04/1974 through 10/1975
*76 produced in Polaris metallic, 33 produced in Chamonix, 1 produced with Special Paint
Where was the 3.0 CSL produced?
Like all 3.0-liter E9-series coupes, the 3.0 CSL was assembled at the Karmann Werkes in Rheine, Germany.
Does the 3.0 CSL have a unique chassis number sequence?
The original carbureted CSLs were based upon standard 3.0 CS production models and therefore have no unique model code or chassis sequence. Instead, their chassis numbers (VINs) fall within the normal 3.0 CS production sequence. However, all fuel-injected CSLs have a unique model code and chassis number sequence. Fuel-injected CSLs with the 3.0-liter motor have VINs that run from 2275001 through 2275429 (left-hand drive version) and 2285001 through 2285500 (right-hand drive version). The final 3.2-liter CSLs (commonly referred to as "Batmobiles") have VINs that run from 2275430 through 2275539 (first batch) and 4355001 through 4355057 (second batch).
Drivetrain
What engines were fitted to the 3.0 CSL?
The engine used in the first version of the 3.0 CSL was entirely unchanged from the standard 2,985-cc M30 inline-6 found in the 3.0 S/3.0 CS models. With an 89mm bore, an 80mm stroke and dual Zenith carburetors, this unit produced 180 hp (DIN) at 6,000 rpm and 192 lb/ft of torque at 3,700 rpm.
The second version of the 3.0 CSL carried over this same basic engine configuration but the bore was increased very slightly to 89.25mm (for a new overall displacement of 3,003cc) and the twin Zenith carbureotrs were replaced by an electronically-controled Bosch fuel injection system. Horsepower increased to 200 hp (DIN) at 5,500 rpm and torque increased to 204 lb/ft at 4,300 rpm. Though these were identical outputs to the standard fuel-injected 2,985-cc unit found in the 3.0 Si/3.0 CSi models, the slightly larger displacement allowed the competition model to compete in the "Over 3.0-liter" class, which had effectively no limit on engine size.
The final version of the 3.0 CSL utilized a further enlarged version of the fuel-injected M30 powerplant with a longer 84mm stroke for a new overall displacement of 3,153cc. Peak power and torque both increased slightly to 206 hp (DIN) at 5,600 rpm and 215 lb/ft at 4,200 rpm, respectively.
What transmissions were offered on the 3.0 CSL?
All 3.0 CSLs were equipped with the same Getrag four-speed manual gearbox found in other three-liter E9 coupes and utilized the same gear ratios: 3.855 (1), 2.20 (2), 1.40 (3), 1.00 (4). This was mated to a limited slip rear differential (25 percent locking) with an axle ratio of either 3.45:1 (carbureted model) or 3.25:1 (all fuel-injected models).
Chassis
How is the suspension of the 3.0 CSL different from that of the 3.0 CS/3.0 CSi?
Though made up of the same basic MacPherson strut/semi-trailing arm design as all E9 coupes, the CSL incorporates the following changes:
-Bilstein gas-pressurized shocks
-specific progressive-rate springs with 20mm reduced height
-increased camber (1.1-degree in the front, 1.0-degree in the rear)
NOTE: CSLs are not equipped with front or rear anti-roll bars
What kind of steering system is fitted to the 3.0 CSL?
Like all E9 coupes, the 3.0 CSL utilizes a ZF worm and roller steering system, though it is different in two respects: the overall ratio is slightly longer (18.9:1 versus 18.0:1) and it is not power assisted except as an option or when equipped with the available "City Package".
What kind of brakes are fitted to the 3.0 CSL?
The 3.0 CSL is equipped with the same 10.7-inch disc brakes on all four corners as the standard 3.0 CS/3.0 CSi models.
What size wheels and tires is the 3.0 CSL equipped with?
All 3.0 CSL models are fitted with Alpina 7x14-inch alloy wheels wearing 195/70VR14 tires (originally Michelin XWX).
Cosmetics
How does the exterior of the 3.0 CSL differ cosmetically from the standard 3.0 CS/3.0CSi?
The 3.0 CSL can be distinguished from its 3.0 CS/3.0 CSi counterparts by the following items:
-aluminum hood, doors and trunk lid
-chrome fender lip extensions
-black side stripe with the "3.0 CSL" logo
-racing-style pin release for the hood*
-lack of front bumper*
-lightweight (5.5 lbs.) plastic rear bumper without overriders*
-"Verbel" laminated windshield
-lightweight window glass*
-fixed rear side windows*
-lack of trunk lock and tool kit*
-Alpina 7x14-inch alloy wheels
*does not apply to most UK-spec right-hand drive examples or those with the City Package
In addition, the final 3.2-liter CSL models differed cosmetically from the earlier models by including the following:
-front airdam
-black rubber air guides on the front fenders
-steel trunk lid with plastic rear spoiler and rubber lip
-"3.0 CSL" decal in place of metal rear model badge
-tri-color stripes on side and front airdam (Chamonix and Polaris metallic cars only)
-removable "racing kit" consisting of an air guide above the rear window and large rear spoiler (16 percent less drag)
How does the interior of the 3.0 CSL differ cosmetically from the standard 3.0 CS/3.0CSi?
The interior of the 3.0 CSL can be distinguished from that of the 3.0 CS/3.0 CSi models by its unique three-spoke leather-wrapped steering wheel and Scheel sport seats in black cloth upholstery with black leatherette bolsters. In addition, the roof lining is also black.
What options were offered on the 3.0 CSL?
Though generally equipped to a minimal specification to retain the lightest curb weight, the 3.0 CSL could be fitted at extra cost with the following features: power front windows (including standard glass), tinted windows (including standard glass), velour carpeting, locking gas cap, air conditioning, headlight washer/wipers and passenger-side mirror.
What is the City Package?
A City Package was offered as an option on all 3.0 CSL models and fitted to the majority of right-hand drive cars sold in the UK. Designed to make the 3.0 CSL more usable as a daily driver, it consisted of the following items:
-steel body panels (not included on all examples)
-power steering
-standard 3.0 CS/3.0 CSi chassis components (including anti-roll bars)
-standard 3.0 CS/3.0 CSi front and rear bumpers
-standard 3.0 CS/3.0 CSi windshield
-standard 3.0 CS/3.0 CSi side glass
-rear-window defroster
-chassis undercoating
-interior hood release
-additional sound deadening
-retractable rear side windows (power-operated)
-tool kit on inner trunk lid
-trunk lock
-velour carpeting
This note is very interesting for a CSL ---- CSLs are not equipped with front or rear anti-roll bars
Were the anti-roll bars installed on the CSL's that were race-prepared?
