cookbw
I've pulled out my driveshaft to replace the center support bearing... hoping to fix a coarse vibration that only occurs under hard acceleration in 1st or 2nd gears. The vibration feels like it's coming from about the location where the center bearing is mounted. There is no vibration at high speeds, just hard acceleration. While under the car, I noticed a couple other things that concern me.
1) Vertical/lateral play in the driveshaft (tranny-to-differential). By grabbing the driveshaft near the center support and tugging on it, I was able to move it side to side about 1/2". That seems like too much to me, but I'm not sure. Looking at the driveshaft/center bearing before I removed them, the rubber in the center bearing is compressed more on the bottom than on top, like it's bearing some weight (see pic below).
2) Rotational play at the differential. With the car sitting on ramps (rear wheels fixed) I can rotate input flange of the differential with my hand about 5mm back and forth and I hear clanking from one side to the other. Does anyone know much play is normal for the diff?
3) The final driveshaft (differential-to-rear wheel) on the driver side is easily moved laterally along its axis of rotation about 1/2 to 3/4" by hand. Passenger side doesn't move much at all. The rubber bellow on driver side is ripped, so I probably need to pull this off and replace anyhow.
As always, helpful tips/feedback are truly appreciated. Thanks!
