Anyone with stock Ate front calipers on their E9 - successfully running 19mm thick pads?
Let me explain.
I have a set of new old stock front brake pads (part number 34112226009) that are clearly marked as fitting 2500, 2800, 3.0CS, 528 and 624 models. The problem is that they are too thick to fit within the caliper and vented rotor assembly. This is with the caliper pistons fully recessed. Pad thickness measures 19 mm. Several sources “suggest” these pads are interchangeable between the E9 and the E24. This can't be accurate (unless the calipers from the E24 are also installed on the E9) http://translate.google.com/transla...irefox-a&rls=org.mozilla:en-US:official&hs=6j To be sure, these thicker pads have the identical footprint as the worn pads currently in the calipers. The only way I think I can get these pads to fit is to physically grind them down, which I would prefer not doing. I suppose I could always grab some solid rotors too. :roll:
Realoem lists a different part number for the E9: 34111159257. Since I do not have a new pad set handy, I am unable to confirm the measurement of this pad. However, the following site suggests these pads should be 15 mm thick. http://www.ultimategarage.com/Parts/padsale.htm
Thanks.
Let me explain.
Thanks.
