How to adjust clutch, if even possible?
teahead
aka "Rob"
Tacoma, WA, USA
Clutch engagement is super low. Grinds going into gear; will barely get into 1st.
Any adjustment on these or I just need to bleed the system or replace/repair the clutch master/slave cylinders?
Sometimes you don't get all the air out. Try bleeding the clutch again (pain, I know, then have a beer....)
If you have the internal slave cylinder, remove it from the bell housing and bleed it upside down.
Isn't their an adjustment where the clutch master connects to the pedal? I recall adjusting the travel on both thecoupe and e3
