PaulinPa
Taking apart my first fuel injected model('75 3.0Si)figure it's same as coupe,but no experience with removing bundle of wires that run from engine thru frame rail and under back seat to controller box.End at back has terminal connector that seems too big to fit thru hole in front floor and hole in rail at engine.End of wire on engine also seems too big to pull thru opposite direction.Do you disconnect all the little wires and then reconnect after you pull it thru??Carbed cars aren't this difficult!
