How to re-order the photos on a post?
Bmachine
Northern California coast
I use the "Upload a File" option a lot. While it is great in that it allows you to display a clickable thumbnail on your post, I can't find any option to re-arrange the order of those photos. It seems to load them based on date but that is not always what you want.
Is there a way to do that?
Thank you.
While still in the "Create Thread" or "Edit Post" (if you're editing an existing post) window, select "Insert every image as thumbnail or full image". Once they are visible in the edit screen (preview screen) you can drag them around to the order you want, then select Save Changes or Post. Try it and post back here if you still need help...
Dan
That helps a lot Dan! Thank you.
I need to play with it a bit more bc the "thumbnails" are quite different and imbedded now but that could be a good thing.
