I'm right in the middle of doing the 5 speed conversion on my coupe. If any of you have installed a short throw shifter, could you please let me know who makes them for this application and where I would get one.
Thanks!
Thanks!
The 265 shifter "platform", that is, steel frame carrier of the shift lever itself, is attached IIRC to the back of the trans at 10 and 2 o'clock by a pair of little rubber bushed aluminum blocks. Trouble (shifter looseness and vague feeling, larger pattern included) comes when the rubber in the blocks starts to disintegrate from heat.
Anyway, relative your interference issue, the condition of the rubbber in the attachment blocks at the back of the trans should be checked. Realistically, they have likely deteriorated somewhat; they are not expensive and should be readily available at the dealer or maybe the aftermarket.
The short shift kit should solve this. The top of the gear shift knob will not have to move as far forward in R,1,3,5 nor rearward in 2 & 4. The short shift kit simply moves the pivot point upwards on the shifter shaft so for the same distance required to move the linkage at the bottom of the shaft, less throw is needed at the top of the shaft.
Thanks!
