CookeD
Hey all,
I'm troubleshooting my rough-running Webers, and a couple of things are suspect. Specifically, I don't have power going to the idle shut-off solenoids, and have a few questions about this:
1. First and foremost, if there is not power going to the solenoids, will I have symptoms that include poor running/will not idle? I've read on-line about snipping the pins off the solenoids that go into the jets, but this doesn't sound like the best thing to do....
2. I have power going into the relay (that's mounted on the rear of the vacuum booster), but there is not power coming out of the lead where the solenoid wires attach. Should this lead have power with the key on, or is this heat-activated (i.e.: Gets power via the temperature lead @ the thermostat)? If I should have power going through the relay with the key on, I've got a relay issue.
3. In bench testing the solenoids, they will not pull themselves in. If I push them in with 12V current going to the solenoid, they will hold themselves in. When I cut the current, they pop out, seemingly as they should. So, should the solenoids pull themselves in with a 12V signal applied? Of course, I need to get the relay problem repaired, but once that is eliminated, I need to make sure the solenoids are operating properly.
Thanks in advance for any help-- I need to be motoring in my "one of the 25 most beautiful cars."
John
John
