Ignition wire
indyken46619
South Bend, IN
Hi,
I was trying to install my new ignition wires on my 3.0 CSi and ran into an issue.
I have new Karlyn 110 w/loom wires with Bremi ends - was told this would work on my CSi. It does not look like the Bremi ends are meant to come off - the old wires had a current donut that slides over one of the wires - this looks like no problem with the old Bosch wires where the ends easily come off.
Any advice?
Thx,
Ken
2260090
if im understanding you correctly... i had a similar problems when i updated the wires/loom on my cs recently. The ends on the new wires wouldnt fit the dizzy. Consultant my local CS guru and he told me to cut the new ends off as the old ends thread onto the plug wires by way of a small tap screw. Had to be careful too cut as little of the wire ends off as possible too maintain length. Just scraped by on the #6 wire but the others went well. Not positive this will work for you. You'll need to verify that your cores are not solid and that the wire diameters are the same as oem. If both of those things check, you should be good.
