Colorado S14
New Member
I picked up a 71 Bavaria from an elderly neighbor earlier this summer.  The car is in great shape with a beautiful interior and pretty good Polaris Silver exterior.  I bought it knowing that there was some work to be done, he said that he had a bad headgasket and that needed replacing.  Well after snagging it from him for a great price I started to do some research and just started to get the inkling that the head instead may be cracked.  Well I finally got around to pulling the head off and taking it down to the machine shop and sure enough we've got ourselves a cracked head.  So now rather than track down a new head I think I may just get myself a junkyard M30 out of a later BMW and drop that in.
Here are the questions that I have:
Is there a best year for these engine when it comes to swap cantidates? From what I have gathered the last revision came in the M30B35 which was after 1988?
I have read posts that have said that the manifolds bolt on to later motors regardless of year, is this the case? I would like to keep it as simple and somewhat period correct as possible so would like to keep the factory carbs if they will just swap over.
Do the bell housings match up for the manual transmission? What about flywheels and clutches, will I need to source those for the engine year?
What about external accessories? Will things like the alternator, etc. bolt up or do I need those off the new engine?
And finally...It appears that the engine mounts are different. Some reference Koala Motorsports adapters but they only list them for E24/28s, are those the ones? If Koala no longer makes them what are my options.
Thanks a ton, looking forward to getting rolling on this bad boy.
