In-tank fuel pump
Sven
Seattle
Does anyone have the part number for the in-tank high pressure fuel pump that Carl Nelson's shop uses for the CS tank (feeding injectors)? They are closed today and I am stuck out of town with a failed pump. I searched the forum and only found reference to the e21. More specifics would help. Thanks
these are the parts my car has in it ... from real oem ... they are from an e24. i also understand that the similar parts from an e21 also work. no idea which parts that Carl Nelson sells ... or what the wiring differences are from stock csi to these parts ... just that this is what is on the car w/ a stock carb cs gas tank and a 3.5 fi engine.
06 Gasket 1
16121116966 $3.64
07 Hex bolt with washerM5X146
07119902007 $0.29
08 SUCTION DEVICE WITH PRE-SUPPLY PUMP
109/1978
16141179425 $230.67
09 SENDING UNIT ASSY METAL TANK 1
16121153050 $138.71
10 Gasket ring 109/1978
16121150391 $4.18
11 Washer 5,3 ZNS409/1978
07119931029 $0.40
Per SFDon:
I buy fuel line from autohausaz....
http://www.autohausaz.com/search/pro...=W0133-1661978,
W0133-1661978
Fuel Hose
$43.25
SALE
I get the pump for an E30, 1992 318is ...
http://www.autohausaz.com/search/ima...6141181075.jpg
The 3 metal fuel lines running along the drivers side of a e23 at the boneyard.
A pipebending tool at homedepot or ebay or??....
http://compare.ebay.com/like/2704032...=263602_304662
Make sure you extend the metal pipes on the pump assembly with fuel line and hose clamps so that the sender and fuel pick up screen are at the same level
Update
The part number for the fuel pump I installed is: 16 14 1 184 022. This is the in-tank high pressure version and not the pre-supply pump. It will need to be extended to reach the bottom of the tank. All my pump problems were caused by a completely plugged fuel filter. It was brand new and must of plugged with debris in the new lines (or been defective). A hard and expensive lesson learned (burned out pumps - maybe).
