sreams
As many of you know, the pre-74 cars don't have enough room for a reel under the rear armrest. I believe the mounting points on the later cars are also configured differently.
I think I've discovered a pretty slick way to end up with retractable 3-point belts in older cars with no real modifications being necessary. I spent a total of $74 for both belts plus a few more dollars for bolts and washers. The trick was to install them upside down... with the reels on the floor. Check it out:
http://www.roadrec.com/csbelt1.jpg
http://www.roadrec.com/csbelt2.jpg
Here are the belts I purchased. They work at any angle (required for our cars regardless of where the reel is mounted):
http://www.ebay.com/itm/221039320884?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I used a cutting wheel to remove the hangars. It takes a little time to get used to pulling the belt from the bottom, but it works well. I may route the belts under the seat hinge in order to avoid getting the belt twisted in the reel.
BTW... This also avoids the need for a slot at the rear seat armrest, since the seatbelt doesn't need to slide in and out at that point.
-Scott
-Scott
