corsachili
I've got a very strange symptom in a CSL I recently assembled and am trying to get running. The engine will start, and run for about 5 seconds, and then die. It won't ever run for more than 5 seconds. My first thought was fuel, because it acts like it's not getting enough, or that it's completely fuel starved. I put a fuel pressure gauge on the hose feeding the rail and it's got a solid 30PSI until the engine dies, so it's not the fuel pump. The fuel injectors are all newly rebuilt and calibrated.
I swapped out the ECU, main relay, manifold press. sensor, a complete distributor, the coil, and the throttle position sensor with good parts (out of my own, running CSL). None of these cured the behavior.
Other strange symptoms are that the throttle is totally unresponsive during the precious few seconds that it runs, and that the brake booster hose nipple, which does not have the hose connected to it, is drawing air. If you put your finger over the nipple the engine dies immediately. I removed and inspected the throttle body and found nothing awry.
It seems electrical, as if the wiring harness or a bad ground, or frayed wire is preventing the trigger points from doing their job.
Does anyone have any bright ideas as to what I might be missing?
-tj in Los Gatos
-tj in Los Gatos
