pmansson
I had the instruments out for replacement with refurbished ones, installed new 4w lamps except for the turn signal lamp which I left at 2 or 3w.
When I push the instrument holder into its position, there is very little space for a hand to insert the multi sockets into the female sockets mounted on the metal board behind the instruments. This task is always a real bummer and takes sometime to get right. I put the multi instrument out of the way, dangling by its many connections, but it´s still tight and difficult. It took a good half hour to get it all right. (And I didn´t forget the tripmeter wire this time. That is very hard to install properly with the speedometer in place).
Has anybody tried a different method. I thought (for the next time) I would try attaching the multi pin sockets with no instruments connected. That would give me much more space to do this. Then connect all the contacts and insert the lampholders etc. Then attach the instruments to the holder/board which will be tricky when trying to reach for the 2 screws per instrument....
Any other ideas???
Any other ideas???
