Intake manifold parts needed
rover215
Hey, group-
I'm in need of a set of parts for my carb intake manifolds. Not sure if they have a specific name, but they mount underneath the manifolds, directly under the carbs. Coolant runs through them and they're connected to one another. I'm told they aid in cold starts, but mine are so corroded to the point critical metal is missing (at the hose connections). I used someone else's pic to show the parts I need. Anyone have a set available and in useable shape?
Can't you just do without them, bypassing?
I am certain you will find the parts :)
Regards, Alberto
Rover215, are you interested in buying both the intake manifold and related cooling system? I have them but prefer to sell them as a set. The dual Webers that were attached to the manifolds were just recently obligated to someone.
Pls send PM if interested.
Its actually better to buy a replacement because its very hard to remove the old crusty ones without snapping a bolt or two.
Yep- snapped a couple per side. Luckily, after I removed the plates, the remaining fastener bits came free leaving good threads. Still, the hose connections are so corroded and missing bits (chunks) of material.
