Intake Manifolds...
Manifold style preference
  • Total voters
    14
careysd
Phoenix, AZ
For those that have done a fuel injection swap, are you happy with the manifold choice, or would you change it knowing what you know now?
What if originality was not a factor?
I agree with you guys, the log is much more aesthetically pleasing. I have decided on going this route with the 4 cyl runners. Now to decide if I am going with the adapter clips or different injectors.
Ummm- you can buy re-built injectors that fit for the same $$$ that the adapter clips cost WITHOUT any injectors.
That's where I am having the hard time deciding. I already have a low mileage set of Gen III injectors. Does the spray pattern make any noticeable driveability difference?
just finished a Sahara coupe 2 weeks ago with the early injectors - ported, polished, schrick cam and Motronic 1.3.
A nasty little bitch of an engine- waiting for a thousand break-in miles do see how much fun it can be............ one of the big differences is in how fast this engine spins up- very, very quick. Probably not a good engine for a real light flywheel. Very decent low end torque but you get the idea that the real fun will be at 3500+ rpm and it will come on hard.
Very good idle-
Remember that the b35 injectors have a straight stream and not a spray per se.
