Trying to help a friend with a CSi, am wondering what if any porion of the electrical wiring for the injection ignition system on a CSi is fused? Also is there a wiring diagram available for a '72 CSi? Thanks.
Csi wiring diagram, page 105 owners manual. Page 61-0/45 blue service manual. Diagram shows a fuse 12 on the feed for the fuel pump relay. I think this fuse is under the right rear seat close to the relay and brain. I'm older so don't take this as gospel. If fuel pump doesn't work after you blow #8 fuse the power lead for the fuel injection is on the wrong terminal side of the fuse box. Power flow is battery, ignition switch, hot side of fuse box to D jet harness. I hope this helps. Tom BaruchUpdate: When the driver window is put down number eight fuse blows. When the fuse blows the engine will crank but not start. I can’t find a relay in a diagram off number eight fuse? Would it be the fuel pump or some other relay?
Thanks Tom will check it out!Csi wiring diagram, page 105 owners manual. Page 61-0/45 blue service manual. Diagram shows a fuse 12 on the feed for the fuel pump relay. I think this fuse is under the right rear seat close to the relay and brain. I'm older so don't take this as gospel. If fuel pump doesn't work after you blow #8 fuse the power lead for the fuel injection is on the wrong terminal side of the fuse box. Power flow is battery, ignition switch, hot side of fuse box to D jet harness. I hope this helps. Tom Baruch
Yes I am aware of that, his screen name here matches his license plate!Steve - Tom (bmwski) was in Hilton Head with us. (As was e9Wayne.) It does not appear y'all have made that connection.
Further D Jet information, fuel pump fuse #8 is probably correct just make sure it is a blue 25 amp and that the contacts are clean and tensioned.There is nothing in the manual that tells you what that fuse # is. I looked at my fuse ledger (original d Jet)car and no mention of a fuel pump fuse. I guess injection was an addon like AC back then. The window connection is a separate issue , I would move the window down without the engine running to see if fuse blows while noting position of failure. Then it is hunting for a short or a overload on that circuitTrying to help a friend with a CSi, am wondering what if any porion of the electrical wiring for the injection ignition system on a CSi is fused? Also is there a wiring diagram available for a '72 CSi? Thanks.
Hah! Thanks Tom I will check it out and let you know!Ok Steve, it's #7 fuse that is used for the CSI fuel pump. Can't believe I looked at the fuse box ledger and missed that, I'm blaming that on to many great Manhattans. So pull fuse 7 and see if the car dies. If it doesn't then it's wired to the wrong circuit and it could be overloading it. Duh on me.
