84E24
I have a stock 73 3.0cs with triple DCOE 40 webers. I have been having issues with the electric fuel pump. The 1st pump I had was a Delco pulse type that had 4 psi at 30gph. I ran it for about 3 months and it failed on my way to the PVGP and had to be towed 100 miles back home. I replaced it with a Carter rotary type at 4 psi and 70 gph. This was recomended by Redline with no regulator.
Both pumps when steady read 4 psi on the fuel pressure gage. At idle both pumps will cause the gage to flutter between 0 and 8 psi. The Carter will stay between 3 and 8. When I hit the throttle the gage stays at 4 psi.
See this : http://picasaweb.google.com/steve.blingham/20100818RunningCarbS#5506922084233670546
Is this normal ?
What can I do to trust the car again?
What other electric fuel pumps are you triple guys using ?
Do you use a pre pump ?
Thanks, Steve
Is this normal ?
Thanks, Steve
