Tierfreund
Hello all
I have a problem with my front (most likely left side) suspension. I have a nasty knocking noise when going over a bump or pothole with the left front wheel. More prominent when the front left is loaded (fast right-hand cornering), more likely if the bump/hole only hits the front left, less likely if both sides are going up or down.
The noise first came when I hit a very deep pothole this winter.
History:
- All rubber on the chassis was replaced 3 years (60.000mls) ago.
- Replaced the front and rear shocks and springs 3 months ago (makeing the sound more prominent)
- Replaced the wheel bearings on all 4 corners 2 months ago (checked and rechecked the front bearing clearance several times)
- Had the car checked for road-worthyness (german TUEV) where front supension was checked (they put it on sort of a horizontal shaker and check for play in the bushes). Nothing found.
- (Visually) checked all front suspension components several times (including fron anti-roll-bar and it´s rubbers. Found some slack in the anti-roll-bar coupling rod nuts, tightened - to no avail)
Plan:
As they are inexpensive and easy to change, I´ll be changing the anti-roll-bar rubbers this weekend, but I have little hope that´ll fix it.
I´ll also take the front struts apart again and will check everything there (maybe the big nut that holds the front shock in the strut).
Any suggestions / any ideas?
P.S. This is on an E3, but I believe the front suspension to be identical to the E9 and this is the most knowledgeable crowd I know.
History:
Plan:
