knurled bolt on light access panels
rsporsche
Atlanta, GA
guys, if you are in need of new knurled bolts for the light access panels (under the hood), you might be out of luck. part #63121811910 (#5 on the picture). one of mine was loose between the plastic and the machine screw ... and i had to cut the top loose. i went to order them from tomkinson and got a message of NLA. i have no idea if they just need to make more, or if they are gone for the forseeable future ... but none in Germany either. i luckily bought the last 6 from Penske this morning that they happened to have in stock ... and showed up on a recent inventory.
i assume they are white or gray. Penske wasn't specific as to what they had, and as long as they match ... i'm okay. all i know is that BMW isn't currently stocking them.
RSPosche,
I was trying to find these finger screws new for some time, with no luck.
However, I recently sourced some second hand from CoupeKing.
Cheers,
Rod
The original ones were whitish/ translucent and I've seen new runs made out of black plastic. BMW probably doesn't care what color they are as long as they are functional, but I imagine they will keep them in stock in the future...
