John Buchtenkirch
I have swapped the stock coupe turn signal switch over to the left side of my column and I’m attempting to install a steering wheel off an early 7 series car that has the correct spline. My steering shaft has a stamped steel tab on it to turn off the directionals but now it is 180 degrees away from the correct operating location. My question is “has anyone removed that tab and reattached it in the correct location to work the directional switch when moved to the left side” ?
Or “has anyone just cut the stock coupe tab off and used the tab that is attached to the later BMW wheel which by the way I feel is in the correct position rotation wise” ?
I kind of hate to cut off the stock tab because then I would never be able to use the stock so called big bus wheel again if I was lucky enough to find a cherry one but if that’s the best way to go I have to be realistic. As always thanks for everyone’s help, I think I would still be stuck on the 5 speed swap without you guys. ~ John Buchtenkirch
