GGR
OK, so I bought that Getrag 265. It has the pick up for the speedo cable, but is missing the output flange, the three hole thing that connects with the flex disc and prop shaft.
There is also some signs of oil seeping out inbetween the front and the middle sections, on the top of the trans. Is there a gasket there? Is that 25 ton press needed to access that area or can I replace/reseal as a DIY?
Also, I have access to a Getrag 4 speed, must be out of a 2002. Will the output flange fit the 265?
Thanks!
Thanks!
