John Buchtenkirch
Back in the day with American cars you would jack the rear end up and turn a wheel. If the wheel on the other side turned in the same direction you had a posi-traction rear --- if it turned in the opposite direction you had a standard or so called open differential. I’m assuming BMW limited slip rears can be tested in the same way but am not sure ??? Thank you ~ John Buchtenkirch
