Looking for this electrical connector
Luis A.
Wisconsin
Hi guys,
This connector was used on the E3's and I suspect also on the E9's and many other BMW's of the time. I'm in need of two just like the one pictured. Can anyone help? Thanks.
Luis,
I have one from a 2002, probably 16 gauge, not the same colors as yours but same pin configuration. I have a female socket too but pins in different holes.
Chris
Thanks for your reply Chris, if you don't need it I'll be happy to buy it from you. I just need the one pictured, with the male pins. The wire colors are not important since I'll re-pin it. Do you know where in a 2002 it is used?
I still need another one; anyone else has one?
Paul,
I need it for a headlight wiper motor. I know it is used elsewhere in other models but I don't know where... Chris, you know?
No, thanks, that's all I need :), until I find I need another one a month from now... Actually, I've already rebuilt the engine harness, EFI harness and A/C harness so I'm confident this is the last connector I need. If you don't mind, I'll take the make and female, just in case. Thanks a lot!
