I asked about the existence of this light some time ago*. While this warning light has never been a priority, I took a closer examination without success.  Before throwing in the towel, perhaps you folks have some "bright" ideas.
They are perhaps not the most accurate of measuring devices, but my gauges are fairly steady. The fuel gauge typically reads full, half or empty. When the fuel tank is low - but not empty, the gauge reads empty. It has been that way as long as I can remember. On that note, the only evidence I have a low-fuel warning light may have been some passing flickering. Maybe it was only "wishful flickering."
I recently pulled the sender/float assembly in the tank to check for binding. With the ignition on, I could get the gauge to register evenly as I fiddled with the float, but I could not get any low fuel light illumination. The float did not appear to bind at all. I previously removed the bulb and checked it both for corrosion and continuity. It seemed fine. I suppose the plug socket or the circuit board could be buggered up, but I hope that is not the case.
If someone knows, is the low fuel warning light triggered by the fuel level sending unit or is there something else one might consider. One would think that if the gauge reads empty so might the warning glow, but such is not the case. Any constructive thoughts would be appreciated.
Thanks in advance.
*http://e9coupe.com/forum/viewtopic.php?t=190&highlight=low+fuel&sid=1d7a5e8884cb9ab5b02cbbc50f0a7f30
Thanks in advance.
