E9project
New Member
The old rocker shafts used screw in plugs on the exposed ends and aluminum plugs on the inside ends. My BMW replacements just have aluminum plugs on the out ends and an open hole with no threads on the inside ends. Is some kind of plug needed for the inside ends? My old parts manual shows both ends plugged like the original shafts.
Different part of the engine but the same general question. Does the crank have in machining plugs that should be replaced on a rebuild? I know Alfa engines do and they can let go and lose your oil pressure, if they are not replaced.
Thanks, Gerald
Thanks, Gerald
