sreams
I've pulled my original 3.0 out and I am transferring parts to my 1991 M30B35. It will be carbureted (for now).
The first question is regarding the oil pump. I'll be using the old pan. I've moved the pump over from the 3.0 to the new engine and it fits just fine... but it appears the oil pump chain that is currently on the newer engine is not long enough. Is that expected?
The second question: I'd like to switch to the newer style cooling fan that threads on (reverse thread). The M30B35 water pump only has a single groove pulley. I'd like to move my old pulley over, but the mounting holes on the pulley don't match those on the pump. The center hole in the pulley also doesn't match the hub on the pump. Is there any way to do this? Or should I stick with the old style fan/pump?
Thanks ahead for any advice.
-Scott
-Scott
