M535I ON TO CSL
quarry
United Kingdom
Can any one tell me if any of the E12 M535i front suspension is interchangeable with my 1973 CSL? looks the same but not 100%, antiroll bar looks thicker ,but legs etc look same.
Thanks Quarry.
E12 M535i have 24 mm bar. http://bmwfans.info/part-31351113024/
E9 standard bar should be 17 mm. http://bmwfans.info/part-31351103000/
E3 have an 23 mm bar on some cars. http://bmwfans.info/part-31351111983/
And 19 mm on some. http://bmwfans.info/part-31351103021/
I'm not sure but they maybe interchange.
Front axle support are the same on E3 and E9. http://www.realoem.com/bmw/partxref.do?part=31111110230&showus=on&showeur=on
E12 and early E24 are the same. http://www.realoem.com/bmw/partxref.do?part=31111114424&showus=on&showeur=on
I don't know what differs.
Front uprigthts look identical but sadly aren't, they will fit but you will have positive camber as the stub axle is at a slightly different angle. I think the front anti roll bar will fit but you'll need the rubber bushes to fit it to the subframe, the rear anti rollbar is a definate swap and I belive (but am not 100%) that the entire rear subframe can be transfered over to give you a wider rear track. Only problem if you do that is you'll need a non standard off set when fitting wider (ie staggered Alpina's) rear wheels.
