goodolarchie
- Messages
- 25
- Reaction score
- 0
M90 + M30B34 + Motronic = ?
I'm moving to a bigger garage this month which means space to start tearing down the engines in the 3 rigs in my sig :mrgreen:
I've done a bit of research and haven't settled on the best combination to get power to the rear wheels of the E9. Here's my tentative plan:
-Pull E24 M90 and 265CR, finish cleaning and painting the engine bay of E9.
-Refresh bottom end of the M90 (has about 78k on it)
-Refresh the B34 head from e28
-Use the dogleg 265 with a 3.07 side loader (believe the early E24 had this, can't check for a month)
-Could also use the 265 OD with shorter diff
-Deal with Speedo, diff, driveline issues
So that's the laundry list, the goal is use the e28 motronic and keep the M90/265CR since they have so few miles on them and are a joy when paired.
Any issues mating the B24 up to M90? Piston/valve clearance? By my calculation...
575.5 CC per M90 cylinder / 58cc grants a handsome 10:1 CR, still doable on pump gas. If valve clearance is an issue, is a thicker gasket going to fix it?
Cheers
Cheers
