main relay location 3.0 csi?
mikemls
I am in the proces of reviving my 1972 3.0 csi. It seems that I am not getting power to the ecu. After looking over the wiring diagrams, it looks like i need to track down the main relay. Could anyone please tell me where it is located on this car?
Thanks in advance...
Not sure if this will solve your problem. A while back my 72 0.cs would not start. Solved issue by replacing relay located in engine bay attached to firewall slightly to the right of brake booster.
Yes, this is where the main relay is i believe. The fuel pump relay is next to the ECU brain itself i think. Sorry to be vague!
Thanks for the replies.
I was able to locate the fuel pump relay by the ecu.
I have two relays hanging loose on teh firewall above my brake booster, so I'll check those out.
I've recently sorted some electrical issues with relays. A 12v DC power supply was useful in troubleshooting to energize relays. I had a good continuity check of the relay coil, a good Normaly open
of the normally open (NO) contact, but fried contact in the energized closed contact. Sometimes it helps to independently energize the coil when troubleshooting.
$0.02
booster
