Maintenance Items Supplier Source - Recommendations Needed
BikeRider
Maryland
What's the recommended vendor(s) in the US for maintenance items for an E9 CSi?
Oil
Oil filter - with washers and other small parts
Air filter
plugs
etc.
I found the a few threads listing vendors; but can't seem to find one in the US that has everything under one roof. Paying a vendor overseas is a bit of a challenge...at least for me.
New to E9s...Thanks!
I don't have a one-stop shopping vendor I use, and I suspect most others here feel the same way. Most of us have particular stuff we like (I use Redline oil and NGK BP6S plugs) and we buy what we want where we can find it.
Obviously, you can cut your acquisition costs of oil if you buy locally. Lots of folks buy oil from Walmart (Mobil 1) or the local auto parts store (Valvoline).
For those items you list plus belts, PS fluid, brake fluid, coolant, radiator cap, points, condenser, cap, rotor, ignition wires, and other common service items...
If you have a NAPA store nearby, they would likely have everything in stock in most cases with a choice of quality brands.
RockAuto if you don't want to drive to pick up the items. Also Amazon (they even have the Beck Arnley air filter)
