Master Brake Cylinder
84E24
Dayton, Ohio
I have a 1973 3.0cs with a build date of 5/1973 and in the need of a Master Cylinder.
I see that there are 2 different ones listed on the Maximillian site. P/N 34 31 1 103 271 with a D=23.81mm and the second P/N 34 31 1 120 479 with D=22.20mm.
How can I tell which one is on my car? What difference in the bore size make?
Thanks,
well...
other things being equal, a larger bore in the brake master cylinder means less brake pedal stroke length to displace brake fluid into the calipers. However, you lose a little bit of hydraulic advantage, so maybe things even out. The bores are pretty close, aren't they?
What bore size do you have now?
I have not taken it off as yet.
Just looking for a way to id what I have and to see why there are 2 different ones.
Anyone know why?
Thanks,
Brake cylinder
FYI to all in case anyone needs it,
I had the 23,81mm Brake Master Cylinder on my production date 5/73 3.0cs. Max shows the p/n 34 31 1 103 271 being ended. My parts guy crossed the number to 34 31 1 120 832. Same as older E12 and E24.
The 23,81mm does have a larger shaft than the 22,20mm. My guy sent me both so I could compare.
SteveB
Brake cylinder
SteveB
Anyone have any idea where to source the Seal kits ,specifically the one between the Booster and the Master Cylinders??
Walloth& Nesch are out of stock
