There is an option- let's put Sven and Drew (arguably
two of our brighter members) together and have them
report back to the forum about the micro squirt?
Don, I appreciate the nod but honestly, the only reason I know ANYTHING about the MSPNP2 setup is because of the assistance provided by you and Sven, and shared co-miserating discussions with Wayne.
You and Sven are the masters, no doubt, and you are both commended for your willingness to help those of us who often just don't get it.
I am very pleased with the MSPNP2 setup on the Bav. The car runs great and for those considering a conversion from carbs, it was really not that terrible of a task. Not trivial, but definitely doable. That said, it helps to read as much as possible about the systems and operation prior to picking the brains of Sven and Don regarding any specifics related to BMW applications.
For the Coupe I am planning to use the same setup that I did for the Bav. I could have sworn there was an MSPNP3 but looks like I was mistaken. I think the most recent version of PNP2 has additional serial output pins and A/C idle kick up control compared to the version the Bav is running. I am running wasted spark with MSPNP2 and will do the same with the Bav (distributor delete).
Probably one of the biggest challenges is getting the wiring harness right. I built mine from an existing 92 7 series harness and gutted it for all unused wires, then added additional needed for wasted spark and some ground lines and wrapped it all back up. Helps to do it this way so that you can integrate the firewall wire harness grommet so that it does not have to be split/slit. It does not matter if you use an automatic or manual harness as a base, but you need to be sure about the pin mapping on the 55-pin bosch harness.
For 02 controller I used an NGK Powerdex system (~$300), but it looks like there are less expensive options out there now. Crank position sensor was from Autoparts warehouse for about $30. ICV was also purchased from Autoparts warehouse for about $86.
Happy to help with any questions but know that you are getting second tier advice.
Drew
