John Buchtenkirch
I got the correct 12x32x10 (.473”x1.259”x.392”) sealed pilot bearing for my the crankshaft in my 72 coupe but the bearing is obviously too big for the formally automatic crankshaft hole. Is there a steel bushing in the automatic crankshaft hole to reduce the size to .826” (roughly 21 millimeter) for the snout on the torque converter ? Or is there a 12x21x10 sealed pilot bearing available for converting cars with automatic crankshafts ?
I cleaned off the back of the crankshaft with paper towels and lacquer thinner and while I can see circular machining marks real well I can’t pick up a break between the crank and a possible bushing so I don’t want to spend time trying to remove something that may not even be there. As always any thoughts or input on this is much appreciated. ~ John Buchtenkirch
