When it comes to clutch an clutch actuation, the 2800 (E3) and 2800CS (E9) use identical parts for the same year.
But clutch, bellhousing and clutch actuation exist in two kinds for the E3 and the E9. Whit an external clutch slave cylinder or an internal clutch slave cylinder. The switch is somewhere in the 1973 model year.
The 2800CS was only built until 1971, so you allways woulds have had the ealier clutch (external slave). But who knows, what you have today? You may no longer have the first engine, clutch or gearbox, so you need to check. The 2800 (e3) was built from 1969 till 1977, so it comes in all shapes, sizes and vintages (not to mention conditions today...)
In short: As for clutch and clutch parts for your car: There are two kinds. find out which one you have and make sure whatever you buy fits...
