Need a measurement on the underside of the front seat.
Bmachine
Northern California coast
Would anyone be able to give me the following measurement.
I need to know the distance Between the two sliding rails when they are attached to the bottom of the seat. As if i wanted to put a piece of wood between the middle of those two sliders for example:
Thank you.
Thanks Chris. Yes, 45cm.
But in this case I am looking for the space between the inside of the sliding rails.
EDIT: the 45 cm is the inside distance between the two “platforms” whee the rails attach.
17 7/8” between outer rail with the teeth for seat adjustment and inside of inner seat rail. Since you have the rails you can subtract the distance from mounting holes to inner edges too.
Thanks Chris. So that converts to 45.4cm. (I may have moved here 30 years ago but I still can’t get used to these weird imperial measurements...). ;-)
Thank you.
