heads up
I need to replace the valvehead of my 3.0csi, 73mod. I have access to a head originating from a 535i, 86mod. Is this a straight swap?, or does the motronic cam come in conflict with the d-jet injection system? Is it best adviced to pull the old cam and fit it into the 535i head? Any advice is much appreciated. Knut
Knut, I interpret that you need a new cylinder head. All the cylinder heads from injected models will fit, however I expect you have a carburetted motor. You will need to fit an electric fuel pump because the injected head has no provision for driving a mechanical fuel pump. It is not difficult to get and install the electric pump.
Your motor will need either the adaptor for the injected cam, or to use the old cam if it is still in good condition. Check the cam lobes that operate the valves for the front cylinder. Sometimes the bolt holding the oil spray bar has come loose and there was no oil to the front lobes, and they suffered severe wear.
