Matt Dusig
Any ideas how to find 1?
I'm looking for the roundel + the metal outer ring. Is that what this is?
I'm actually looking for the roundel + the metal outer ring. It's actually to put on a sub-woofer block I'm building in the trunk.Hi Matt,
Do you have smooth enamel roundels on your c-pillar, or raised aluminum roundels?
Any idea of where I can get a raised roundel?Ok so it doesn’t matter. There are two styles of c-pillar roundels, and the 74 got a raised roundel in lieu of the enamel version.
Well, I want to attach a c-pillar raised roundel into the sub-woofer wall that will be seen in the center back wall of the trunk.Ah, what you need is a "Sub-woofer roundel" those are very rare!
If you are prepared for the shipping, I may have a NOS post 74 one going spare here in the UK. I will check over the W/E.I'm actually looking for the roundel + the metal outer ring. It's actually to put on a sub-woofer block I'm building in the trunk.
There was one on ebay in Germany earlier this month. They aren’t nearly as common. I’ll poke around and see if it springs up.
