dascoupeguy
guys... need help in identifying this old antenna that was likely installed early in my e9's life.
This was trunk mounted with wiring 'somehow' hooked up to the original Blaupunkt radio.
I do not know how it was hooked up to the radio to power it up/down.
There are only the yellow and red wires that DO operate the unit. There is NO ground wire.
It works up/down when you switch the wires +/- to the battery.
The radio set up included a factory Blaupunkt fader/balance module (VERY period...) but I could not find any switch to operate the antenna the way one would expect.
I would like to use this on the car as it appears to be fully functional.
Can anyone ID this unit? It is not a Hirschmann...
Any help would be appreciated
