dascoupeguy
Here's a long question for you... Hopefully a short answer will follow!
One of my 72 3.0cs (car #1) has an issue... The flasher relay will work when the emergency flasher button is pressed... All lights work... the red flasher button, the green turn signal indicator on the dash and all four corners... they work perfectly.
However, when the turn signal indicator is used (R or L) the green dash 'telltale' will flash only once then quit, but the flasher continues to operate and flash the R or L signals.
In the other 72 coupe (Car # 2), all lights work perfectly. And after swapping the flasher units to test, both flasher units work perfectly in car #2. So the problem is not in the flasher relay. I even tested a third relay to be sure.
I am at a loss as to why the dash 'telltale' does not continue to flash (in car #1) when using the turn signal. Don't know if it is a contact problem in the turn signal switch itself or a wiring issue, ground or???
Any ideas? Thanks, DCG
