crow
New Member
Hi I am attempting to replace rear shocks on my 74 3.0 csi. Don't have any data in the blue books on this subject.
You would think a pretty simple process...but the angle of the bolt that secures the base of the shockie is on an angle toward the ground. To lean the shockie to the correct angle to slide on to the bolt means that it does not line up with the tower that goes into the trunk. You can slide it on to the bolt by rotating the shock so that the top points to the ground, but you can't compress the shock enough to rotate it to the upward position and clear the inner guard.
As an aside, I notice that the top of the shock tower has been cut out before and a replacement piece welded in - perhaps the same issue last time?
Does anyone have any ideas here or am I missing something completely?
Any help is greatly appreciated
Cheers
Andrew
Cheers
Andrew
