Need switches
Need hazard light switch for 1973 3.0cs
Need switch for fog light (green plastic )
Call at (917) 592 9930 or e-mail. [email protected]
No 10 "hazard warning switch": pn 61311353428
No 4 fog lamp switch: pn 61311353589
Dealers and most jobbers would probably have the hazard switch available new. The fog lamp switch is listed as unavailable, but that doesn't mean that new old stock isn't collecting dust on a few shelves.
You might find success with some of the vendors frequently mentioned on this forum: Mesa, Autohaus, Penske,
Double02 salvage, etc.
hth
Needing switches
Suggestion--that you buy buy a new Hazard Switch--used may fail next day.
Check with substituting a rear defrost switch for your fog light switch and replace the screw out bulb cover to a green one that may be easier to find from a failed switch or from a CSi that's being parted.
Needing switches
Suggestion--that you buy a new Hazard Switch--a used one may fail the next day.
Check with substituting a rear defrost switch for your fog light switch and replace the screw out bulb cover from yellow to the green one that may be easier to find from a failed switch or from a CSi that's being parted.
These parts can usually be found at Mesa Performance in Costa Mesa, CA 800-221-6372
