Negative battery clamp broke
nealf
Gladwyne, PA
hi is this the factory clamp I have on my 2800? Tightening down the negative clamp today and it broke. I have the metal fabric ground and the brown cable grounds to the back of the brake bomb. Is there anywhere to buy this same setup these days or do I have to go with a replacement clamp of some sort? Thanks!
Markos thanks for the reply but I am concerned with how the wires from the brown cable AND the metal strap feed into the connector head and then soldered all together or whatever the factory did assuming this is a factory setup. Can anyone confirm this is the original setup?
Thanks.
Your cable looks like a 2002 which has second wire to the block. Buy a factory ground strap. It won’t be braided I don’t think.
