Hello to all. My name is John and I'm new here on e9coupe.com I'm the proud owner of a beautiful '74 CSi Granatrot Metallic example previously owned by Peder Mansson (Sweden & Switzerland) and before Peder, Mr & Mrs Arthur Wegweiser (Pennsylvania). My compliments to Peder, (an active member here on e9coupe.com) for taking such great care of the car!
DRIVER SIDE WINDOW FREEZE-UP
The driver side front window of my would not go down. But when activating the switch up or down a slight click could be heard coming from inside the door. After consulting with HBChris, I removed the door card to investigate. With the door plastic peeled upward, I could see the "sardine" style motor and observed a rubber "bushing" (about 1.25" long. See Photo) connecting the motor drive shaft to the regulator drive shaft. When activating the window switch, I could see the motor "trying" to turn the rubber bushing (the motor driveshaft would turn just slightly but the top of the bushing remained motionless) but unable to start spinning. I then manually turned the rubber bushing while activating the window switch, and the motor started spinning, and window retracted! Original problem solved, for today....
Now for some questions:
Why might the regulator shaft have resisted turning initially?
What might prevent the regulator drive shaft from "freeze-up"? (if that was the culprit). Is it possible the regulator worm gear is wearing out?
Does the window "upper limit" rubber stop need to be adjusted slightly to prevent window from going so high?
By the way, everything looks well-lubricated with fresh grease.
