Polariscsl
Hi All,
I have been a long time visitor to this forum but decided it was time to introduce myself. Firstly though I have to compliment the forum because it certainly is a wealth of knowledge run by true enthusiasts.
I am the proud owner of an early CSL that was the lucky and needy recipient of a 5 year ground up restoration. (I will post some pics when I figure out how).
My key issue at the moment results from me converting it to triple webbers recently. The linkage side is bespoke and perfect in its operation but I am struggling with what I should do on the igniton/ distributor side. Currently the car runs quite rough on part throttle and pops quite a lot. I am running the stock vac advance distributor, lumention electronics and magnecor leads. The vacuum advance is currently not connected. I have searched the forum and found many solutions to this - basically I wan to sort this with the best solution possible and want to be sure before i throw money at the problem as always seems to be the case with CSL's.
Do i need a fixed advance distributor like a mallory with some form of electronic ignition? or would it be better to just fit a mapped ignition like an emerald or omex?
The key problem that i face is a lack of expertise setting up webbers - I know more about mapping modern ecu's.... [/img]
