Carbs are new per the ad, which is an interesting thing to invest in given all that this car needs.
In addition to the rust concerns, there is a lot of stuff missing - rocker panel trim, trim under the steering wheel, accessory door, glove box, A/C controls and under hood components, the radio, center caps on the rear wheels and a license plate indicating registration.
Fuel lines are a mess, unused portions of the previous linkage are still there, vacuum line to the brake booster is taped and zip tied, brake reservoir shows low brake fluid, there is a splice in the hose to the reservoir tank, door pulls are missing, A/C controls (and the under-hood components) are missing, door cards appear to be screwed onto the doors, and there is a lot of stray, unwrapped wiring under the hood.
And while my prior comment about the ground cable on the battery was rather flip, I would be seriously concerned about a mechanic who used a red cable for the battery ground. If ever someone needs to jump this car, they will be in for a nasty surprise.
At $8,500 I wasn't too critical, but at $45,000, 2270285 is open for criticism.
