Key on to run- push down on throttle linkage at throttle body quickly.
You should hear all your injectors fire.
What year? Wiring harnesses change over the years.
Do you have a white wire at your resister?
That turns on the main relay.
Main relay feeds pins 16 and 24 on ecu. Got voltage at main relay pin 87?
Jumper your fuel relay and try again after listening for pump running.
