Ich bin ein E9er
I have had my 70 coupe for just over a year now and am enjoying it immensely. The problem has been a very annoying whine from the gearbox (I thought). The whine pitch gets higher as speed increases. My car some time in its life received a 3.0 engine with Webber carbs and a 265 Getrag five speed. I found a replacement 265 on craigs list and it has been sitting in the garage waiting for me to install it. This past weekend I took the plunge and pulled out the old trans and installed the new one (note that the “new” one is an unrestored used box). So last night after I get everything buttoned up I take her out for a spin. Guess what, same whine. So either the replacement trans has the exact problem as the old one or the whine is not coming from the gear box. Now I need advice from the experts. Is the 265 Getrag prone to whines or should I be looking elsewhere for the cause. I reused the same center carrier bearing and guibo, both seemed fine with no slop in the center bearing and the guibo rubber looked good with no cracks. One thing with the guibo was that the holes didn’t line up perfectly with the holes in the flanges in the trans or the driveshaft. I had to squeeze the guibo with a c-clamp to get the bolts to line up, is this normal? Any input is appreciated.
Thanks,
Steve
Thanks,
Steve
