North Hollywood Speedometer
EJ333
Southern Cal
I would like to have a consistently working clock, but at what price ? Has anyone taken their coupe to this shop and had it refurbished and reinstalled by the good people here ? I have a 71' 2800cs, and would like to have a Quartz upgrade, but like another member here, Don, said it may not be always possible. What might the total cost be including labor ? I don't mind paying an arm, but an arm and a leg for a working clock ? I live within driving distance and don't want to go through the frustration of dash dismantling etc.
you dont have to dismantle the dash to get it out, it only takes a few minutes and no other gauges or dash pieces have to come out other than the under panel. I took my firend's out and he sent it to NHS, I put it back in, a month later it broke, I took it out again. They are going to fix it for no cost, but maybe these clocks just don't repair well or???
You may not have to disassemble your dash, depending on your dexterity but certainly the panel under the steering column has to come out if you are to remove the clock.
I have read $125 for quartz replacement. It may be worth that to you depending on the general condition of your coupe and wallet. Getting the works out of the can the clock is sealed in, is not for the faint of heart. In my case I have two, so little to lose.
I was able to muck with (technical term) my spare clock on the kitchen table and voila, it worked. Don't really know what I did, maybe it always worked and only needed juice. Maybe it was a connection thing, maybe it was flattered by the attention, maybe it feared my "nothing to lose" attitude, maybe it was a secret member of some Anti-vivisection organization.
Be sure your clock has power and ground before messing with it. Also check that the lights illuminate the clock when the headlights are on, although lights won't mean the clock will work.
For me to remove/replace a clock requires my XL hands getting up under the dash, generally as follows.
Each round instrument "group" is held to the dash wood by two knurled nuts on studs which project forward from each group. If you can snake your hand up and in, unscrew those nuts, and the group can be rotated about "1 hour" in one direction (forget which) and it will release from the wood. Then you can lower it and disconnect the wires. For the clock there are I think three wires: power to clock, ground, and power to lights. Installation is as they say the reverse of removal.
If you search out a picture of the instruments (such pics are on this list), you'll see what's involved. See post number 278 and a few following here: http://www.e9coupe.com/forum/showthread.php?t=17735&page=28
Not the price but the time. They do great work but quoted me 4monts for a complete set of gauges this week.
Per my other current thread on this, D&M Restoration <http://dandmrestoration.com/services/clocks/> charged me $250 for a complete refurb of my '71 2800CS clock. They did my 3.0 clock about 20 years ago for $125, so I guess I should not have been surprised -- but that still seems like a lot. I did not price-shop. I am very pleased with their work. Warranted for a year.
Another idea on gauge removal: There is a bolt at the left and right end of the hood portion of the dash that covers the gauge cluster. The bolts point to the front of the car and secure the hood to the metal structure behind the dash. On my previous coupe, I just left the nuts off of these and could easily pull the whole cluster toward the steering wheel whenever I needed access behind them. YMMV.
Don
I took all my e9 instruments to NoHo Speedo based on the fact that Paul Cain had his done there. I removed and reinstalled the instruments myself.
They converted the clock to quartz, cleaned all dials, and repainted all instrument arms. I couldn't be happier with their work. Its been a few years, but I recall it taking a few weeks (not months) and around $100 to $200 per gauge. The problem is if you do just one gauge, the others look conspicuously crappy.
N.H. Speedo
I did the same about a year ago. When I had my dash out, all instruments operational, so I just had them cleaned. I had the clock converted to quartz and
it keeps perfect time. They all look new and it only cost about $200.00 was about $200.00. I thought it was very reasonable.
